Страница 6 из 6 ПерваяПервая ... 56
Показано с 51 по 58 из 58
Тема: Скрипты для WSH Panel Mod и JScript Panel
  1. #51
    23.10.2023
    61
    WSH Search by kgena_ua
    Подскажите, этот скрипт может искать не по Библиотеке, а по текущему плейлисту?
    Код:
    function RGB(r,g,b) { return (0xff000000|(r<<16)|(g<<8)|(b)); }
    function RGBA(r, g, b, a) { return ((a << 24) | (r << 16) | (g << 8) | (b)); }
    var font = gdi.Font("arial",12,1);
    var font2 = gdi.Font("arial",10,0);
    var ww = window.Width;
    var wh = window.Height;
    DT_CENTER = 0x00000001;
    DT_RIGHT = 0x00000002;
    DT_SINGLELINE = 0x00000020;
    DT_VCENTER = 0x00000004;
    var t_color = RGB(180,180,180);
    var m_color = RGB(120,120,120);
    var sel_color = RGB(250,250,250);
    var sel_bg_color = RGB(100,100,100);
    var t_row = 1, t_row1, t_row2, t_row3, t_height;
    var string = "", search_query;
    var tag_search = window.GetProperty("tag_search", 1);
    var previous_pll = plman.ActivePlaylist;
    var sort = "%album artist%|%date%|%album%|%discnumber%|%tracknumber%|%title%";
    var on_mouse = false;
    var ab, ab1, ab2;
    var ab_I, ab_C, ab_F, ab_M;
    var it, it1, it2, itM;
    var line1 = false, line2 = false, line3 = false;
    var lang = 1;
    function on_paint(gr) {
        gr.FillSolidRect (0, 0, ww, wh, RGB(30,30,30));
        t_height = gr.CalcTextheight("abc", font) + 3;
        t_row1 = t_row + t_height + 0;
        t_row2 = t_row1 + t_height + 0;
        t_row3 = t_row2 + t_height + 0;
        ab_I = Array("A","B","C","D","E","F","G","H","I","J","K","L","M","N","O","P","Q","R","S","T","U","V","W","X","Y","Z"," ","<","...")
        ab_F = Array("1","2","3","4","5","6","7","8","9","0","/","'","#",",","-",":"," ","<","...")
        ab_C = Array("А","Б","В","Г","Д","Е","Ё","Ж","З","И","Й","К","Л","М","Н","О","П","Р","С","Т","У","Ф","Х","Ц","Ч","Ш","Щ","Ъ","Ы","Ь","Э","Ю","Я"," ","<","...")
        ab_M = Array("all","artist","album","title","genre","date","rating");
        if (lang == 1) ab_M = ab_M.concat("ая","09");
        if (lang == 2) ab_M = ab_M.concat("az","09");
        if (lang == 3) ab_M = ab_M.concat("az","ая");
        itM = ab_M.length;
        if (lang == 1) ab = ab_I;
        if (lang == 2) ab = ab_C;
        if (lang == 3) ab = ab_F;
        it = ab.length;
        it1 = Math.round(it/2);
        it2 = it - it1;
        ab1 = ab.splice(0,it1);
        ab2 = ab.splice(0,it2);
        if(on_mouse && line1) gr.FillSolidRect (x_col1, t_row1, ww / it1, t_height, sel_bg_color);
        if(on_mouse && line2) gr.FillSolidRect (x_col2, t_row2, ww / it2, t_height, sel_bg_color);
        if(on_mouse && line3) gr.FillSolidRect (x_col3, t_row3, ww / itM, t_height, sel_bg_color);
        gr.GdiDrawText(string, font, search ? sel_color : t_color, 10, t_row, ww , t_height, DT_SINGLELINE | DT_VCENTER);
        for (var i = 0; i < it1; i = i + 1) {
            color = x_color > ww / it1 * i && x_color < ww / it1 * (i + 1) && on_mouse && line1 ? sel_color : t_color;
            gr.GdiDrawText(ab1[i] == " " ? "_" : ab1[i], font, color, ww / it1 * i, t_row1, ww / it1 , t_height, DT_CENTER |DT_SINGLELINE | DT_VCENTER);
        for (var i = 0; i < it2; i = i + 1) {
            color = x_color > ww / it2 * i && x_color < ww / it2 * (i + 1) && on_mouse && line2 ? sel_color : t_color;
            gr.GdiDrawText(ab2[i] == " " ? "_" : ab2[i], font, color, ww / it2 * i, t_row2, ww / it2 , t_height, DT_CENTER |DT_SINGLELINE | DT_VCENTER);
        for (var i = 0; i < itM; i = i + 1) {
            color = (x_color > ww / itM * i && x_color < ww / itM * (i + 1) && on_mouse && line3) || tag_search == i + 1 ? sel_color : m_color;
            gr.GdiDrawText(ab_M[i], font2, color, ww / itM * i, t_row3, ww / itM , t_height, DT_CENTER |DT_SINGLELINE | DT_VCENTER);
    //    gr.GdiDrawText(line1 + " " + line2 + " " + line3, font2, RGB(200,200,200), 0, 5, ww - 10  , wh, DT_RIGHT);
    var ch;
    var x_col1, x_col2, x_col3;
    var x_color;
    function on_mouse_lbtn_up (x, y){
        line1 = y >= t_row1 && y <= t_row1 + t_height ? true : false;
        line2 = y >= t_row2 && y <= t_row2 + t_height ? true : false;
        line3 = y >= t_row3 && y <= t_row3 + t_height ? true : false;
        if (!line1 && !line2 && !line3) return; // ???
        if (!search) previous_pll = plman.ActivePlaylist;
        library_view_idx();
            if (x > ww / it1 * i && x < ww / it1 * (i + 1) && line1) {ch = ab1[i]}
            if (x > ww / it2 * i && x < ww / it2 * (i + 1) && line2) {ch = ab2[i]}
            if (x > ww / itM * i && x < ww / itM * (i + 1) && line3) {
                if (i < itM - 2) {
                    tag_search = i + 1; tag_search_change();return;
                } else {
                    ch = ab_M[i] }
        if (ch == "az") {ch = ""; lang = 1; return};
        if (ch == "ая") {ch = ""; lang = 2; return};
        if (ch == "09") {ch = ""; lang = 3; return};
        if (ch == "<")  {ch = ""; string = string.substring(0,string.length - 1)};
        if (ch == "..."){ch = ""; string = ""};
        string = string + ch;
        string = string.charAt(0) == " " ? "" : string;
        string = string.replace("  "," ");
        if (string.length > 0 || search) pll_search();
    var search = false;
    var count;
    function pll_search() {
        remove_pll("search");
        switch(tag_search) {
            case 1:
                search_query =  "%artist% HAS " + string + " OR " + "%album% HAS " + string + " OR " + "%title% HAS " + string + " OR " + "%genre% HAS " + string + " OR " + "%date% HAS " + string;
                break;
            case 2:
                search_query =  "%artist% HAS " + string;
                break;
            case 3:
                search_query =  "%album% HAS " + string;
                break;
            case 4:
                search_query =  "%title% HAS " + string;
                break;
            case 5:
                search_query =  "%genre% HAS " + string;
                break;
            case 6:
                search_query =  "%date% HAS " + string;
                break;
            case 7:
                search_query =  "rating HAS "  + string.charAt(0) + " OR " + "%rating% HAS " + string.charAt(0)
                                + " OR " + "rating HAS "  + string.charAt(1) + " OR " + "%rating% HAS " + string.charAt(1)
                                + " OR " + "rating HAS "  + string.charAt(2) + " OR " + "%rating% HAS " + string.charAt(2)
                                + " OR " + "rating HAS "  + string.charAt(3) + " OR " + "%rating% HAS " + string.charAt(3)
                                + " OR " + "rating HAS "  + string.charAt(4) + " OR " + "%rating% HAS " + string.charAt(4)
                break;
        idx = plman.PlaylistCount;
        fb.CreateAutoPlaylist(idx, "search", search_query, sort, 0);
        count = fb.PlaylistItemCount(idx)
        if (count > 0) {
            fb.ActivePlaylist = idx; search = true
        } else {
    //        fb.ActivePlaylist = previous_pll;   // ???
    //        fb.ActivePlaylist = 0;            // ???
            fb.ActivePlaylist = lib_v_idx;    // ???
            search = false;
    function remove_pll(pll_name){
        search = false;
        remove_idx = fb.PlaylistCount;
        for (var i = 0; i < remove_idx; i++) {
           if (fb.GetPlaylistName(i) == pll_name) {fb.RemovePlaylist(i)}
    var lib_v_idx;
    function library_view_idx(){
        for (var i = 0; i < idx; i++) {
           if (fb.GetPlaylistName(i) == "Library view") {lib_v_idx = i}
    function on_playback_starting(cmd, is_paused) {
        string = "";
        search = false;
        if (fb.GetPlaylistName(fb.ActivePlaylist) != "search") {remove_pll("search");}
    function on_mouse_move(x,y) {
        window.SetCursor(32649);
        on_mouse = true;
        x_color = x;
            if (x > ww / it1 * i) {x_col1 = ww / it1 * i}
            if (x > ww / it2 * i) {x_col2 = ww / it2 * i}
            if (x > ww / itM * i) {x_col3 = ww / itM * i}
        window.Repaint();
    function on_size(){
        ww = window.Width;
        wh = window.Height;
    function on_mouse_leave() {
        window.SetCursor(32512);
        on_mouse = false;
        window.Repaint();
    function on_mouse_rbtn_up (x, y){
        var _menu = window.CreatePopupMenu();
        var i = 1;
        _menu.AppendMenuItem(0x00000000, i++, "all");
        _menu.AppendMenuItem(0x00000000, i++, "artist");
        _menu.AppendMenuItem(0x00000000, i++, "album");
        _menu.AppendMenuItem(0x00000000, i++, "title");
        _menu.AppendMenuItem(0x00000000, i++, "genre");
        _menu.AppendMenuItem(0x00000000, i++, "date");
        _menu.AppendMenuItem(0x00000000, i++, "rating");
        _menu.CheckMenuRadioItem(1, i, tag_search);
        _menu.EnableMenuItem(tag_search, 1);
        _menu.AppendMenuItem(0x00000800, 0, 0);
        _menu.AppendMenuItem(0x00000000, 10, "Configure ...");
        ret = _menu.TrackPopupMenu(x, y);
        if (ret == 0) return;
        switch (ret) {
        case 1:
        case 2:
        case 3:
        case 4:
        case 5:
        case 6:
        case 7:
            tag_search = 7;
            break;
        case 10:
            window.ShowConfigure();
            break;
        _menu.Dispose();
        return true;
    function tag_search_change(){
        window.SetProperty("tag_search", tag_search);
        if (string.length > 0) pll_search();
    Есть что-то подобное для WSH Panel Mod (1.5.6) с поиском по тегам по текущему плейлисту?
  2. #52
    2 096
    g00drich, всем этим требованиям и даже больше, соответствует Quick Search Toolbar (Панель быстрого поиска).
  3. #53
    23.10.2023
    61
    С компонентами все понятно, остановился на Facets.
    Я хочу попробовать добавить элементы поиска в готовый скрипт WSH Panel Mod, для своей задумки.
    Все что попалось из скриптов с поиском, работает в основном через авто-плейлист, который смотрит всю библиотеку, а не текущий плейлист...
  4. #54
    2 096
    Судя по интерфейсу, этот скрипт панели поиска создавался для работы с сенсорным экраном, когда нет клавиатуры (предположение).
    Если именно это и нужно, то заметил заремленные строки в коде, возможно kgena_ua планировал добавить и поиск по плейлистам:
    Код:
        if (count > 0) {
        } else {
            search = false;
    Попробуйте, может получится добавить поиск и по плейлистам...
  5. #55
    23.10.2023
    61
    Tag Results
    Нашел вот такой скрипт, назовем его "Tag Results".
    Работает с текущим плейлистом, собирает тэги и выдает их значение, плюс сортирует в новом плейлисте по значениям.
Название:	Tag Results_02-04-2025_01.jpg
Название:	Tag Results_02-04-2025_02.jpg
    Код:
    function RGB(r, g, b) {
        return (0xff000000 | (r << 16) | (g << 8) | (b));
    IDC_ARROW = 32512;
    IDC_HAND = 32649;
    // window.SetCursor()
    NOT_FOUND = 4294967295;
    // MetaFind() and elsewhere for consistency
    Colors, coordinates, etc
    // General
    meta_field = "rating";
    tag_delimiter = ";";
    working_playlist_name = "Tag Results";
    playing_playlist_name = "Tag Results (Playback)";
    font_std = gdi.Font("Segoe UI", 10, 0);
    font_bold = gdi.Font("Segoe UI", 10, 1);
    font_ital = gdi.Font("Segoe UI", 10, 2);
    // Tags
    t_x = 8;
    t_y = 8;
    t_spc = 8;
    little_x = "ˣ";
    label_color = RGB(151, 181, 192);
    label_text_color = RGB(252, 252, 252);
    fallback_text = "nothing here";
    fallback_text_color = RGB(205, 205, 205);
    // Status
    s_x = 24;
    s_y = 32;
    status_line = "Found %t %btag%s in playlist:"
    status_text_color = RGB(49, 49, 49);
    // Columns
    c_y = 55;
    row_h = 24;
    row_w = .8; // %
    column_indent = 8;
    no_of_columns = 5;
    scroll_step = 1;
    text_omitted = " ...";
    tag_name_color = RGB(49, 49, 49);
    alt_row_color = RGB(241, 246, 243);
    Playlist dict
    function build_dict() {
        tag_dict = {};
        for (n = 0; n < playlistdb.Count; n++) {
            track = playlistdb.Item(n);
            metadb = track.GetFileInfo();
            tag_idx = metadb.MetaFind(meta_field);
            if (tag_idx == NOT_FOUND)
                continue;
            tag_cnt = metadb.MetaValueCount(tag_idx);
            for (t = 0; t < tag_cnt; t++) {
                tag = metadb.MetaValue(tag_idx, t);
                dict_push(tag, track, tag_dict);
    function get_keys(dict) {
        keys = [];
        for (key in dict)
            keys.push(key);
        return keys;
    function dict_push(key, v, dict) {
        if (!(key in dict))
            dict[key] = plman.GetPlaylistItems(-1);
        dict[key].Add(v);
    Playlist utility
    function assess_playlist() {
        playlistdb = plman.GetPlaylistItems(parent_playlist);
        build_dict();
        playlistdb.RemoveAll();
    function playlist_add(tag) {
        new_tag = tag_dict[tag];
        switch (mode) {
            case "&&":
                playlistdb = new_tag.Clone();
                build_dict();
                break;
            case "||":
                playlistdb.AddRange(new_tag);
                break;
    function remake_playlist() {
        assess_playlist();
        for (tag in active_tags) {
            playlist_add(tag);
    function update_playlist() {
        suppress_pl_events = true;
        switch (working_playlist_index) {
            case fb.PlayingPlaylist:
                freeze_playlist();
            case NOT_FOUND:
                make_playlist();
        focus_playlist();
        clear_playlist();
        plman.InsertPlaylistItems(working_playlist_index, 0, playlistdb);
    function make_playlist() {
        working_playlist_index = fb.PlaylistCount;
        fb.CreatePlaylist(working_playlist_index, working_playlist_name);
    function focus_playlist() {
        fb.ActivePlaylist = working_playlist_index;
    function clear_playlist() {
        selection = [];
        p_c = fb.PlaylistItemCount(fb.ActivePlaylist);
        for (idx = 0; idx < p_c; idx++) {
            selection.push(idx);
        plman.SetPlaylistSelection(fb.ActivePlaylist, selection, true);
        plman.RemovePlaylistSelection(fb.ActivePlaylist);
    function freeze_playlist() {
        fb.RenamePlaylist(working_playlist_index, playing_playlist_name);
        playing_playlist_index = working_playlist_index;
    function locate_playlists() {
        // Called on init and on_playlists_changed()
        working_playlist_index = NOT_FOUND,
            playing_playlist_index = NOT_FOUND;
        for (pl_idx = 0; pl_idx < fb.PlaylistCount; pl_idx++) {
            pl_name = plman.GetPlaylistName(pl_idx);
            if (pl_name == working_playlist_name) {
                working_playlist_index = pl_idx;
            } else if (pl_name == playing_playlist_name) {
                playing_playlist_index = pl_idx;
    Tags
    function draw_labels(gr) {
        x = t_x;
        y = t_y;
        run_w = t_x;
        if (len_active_tags() == 0) {
            w = gr.CalcTextWidth(fallback_text, font_ital),
                h = gr.CalcTextHeight(fallback_text, font_ital);
            gr.GdiDrawText(fallback_text, font_ital, fallback_text_color, x, y, w, h);
        } else {
                active_tags[tag].draw(gr);
    label = function(tag) {
        this.name = tag;
        this.draw = function(gr) {
            txt_w = gr.CalcTextWidth(this.name, font_std),
                txt_h = gr.CalcTextHeight(this.name, font_std);
            x = t_x + run_w;
            y = t_y;
            txt_pad_r = txt_h,
                txt_pad_l = txt_h / 2,
                bg_w = txt_pad_l + txt_w + txt_pad_r,
                bg_h = txt_h + 3,
                bg_arc = bg_h / 2,
                text_x = x + txt_pad_l,
                text_y = y + 1,
                close_x = x + txt_w + txt_pad_r - 3,
                close_y = y + 4;
            gr.SetSmoothingMode(2);
            gr.FillRoundRect(x, y, bg_w, bg_h, bg_arc, bg_arc, label_color);
            gr.GdiDrawText(this.name, font_std, label_text_color, text_x, text_y, txt_w, txt_h);
            gr.GdiDrawText(little_x, font_std, label_text_color, close_x, close_y, txt_h, txt_h, label_color);
            run_w += bg_w + t_spc;
            this.left = x,
                this.right = x + bg_w,
                this.top = y,
                this.bottom = y + bg_h;
        this.check_mouse = function(evt, x, y) {
            mouse_is_over = (x >= this.left && x <= this.right &&
                y >= this.top && y <= this.bottom);
            if (mouse_is_over) {
                switch (evt) {
                    case "up":
                        dismiss(this.name);
                        break;
                    case "move":
                        set_hand_cursor = true;
                        break;
    function len_active_tags() {
        n = 0;
            n++;
        return n;
    Status
    function say_status(gr) {
        text = status_line;
        text = text.replace("%t", tags.tags.length)
            .replace("%b", len_active_tags() > 0 && mode == "&&" ? "sub" : "")
            .replace("%s", tags.tags.length == 1 ? "" : "s")
            .replace("%a", len_active_tags())
            .replace("%S", len_active_tags() == 1 ? "" : "s")
            .replace("%p", fb.PlaylistItemCount(fb.ActivePlaylist));
        text_w = gr.CalcTextWidth(text, font_ital);
        text_h = gr.CalcTextHeight(text, font_ital);
        gr.GdiDrawText(text, font_ital, status_text_color, s_x, s_y, text_w, text_h);
    Columns
    tag_list = function() {
        this.update = function() {
            this.offset = 0;
            this.tags = get_keys(tag_dict);
            this.tags.sort();
            space_avail = (wh - c_y);
            total_rows = Math.ceil(this.tags.length / no_of_columns);
            rows_possible = Math.floor(space_avail / row_h) - 1;
            this.visible_rows = Math.min(rows_possible, total_rows);
            this.out_of_bounds = total_rows - this.visible_rows;
        this.draw_rows = function(gr) {
            h = row_h;
            w = row_w * ww;
            x = (ww - w) / 2;
            y = c_y;
            min = this.offset;
            max = this.offset + this.visible_rows;
            for (n = min; n < max; n++) {
                if (n % 2 == 0) {
                    gr.FillSolidRect(x, y, w, h, alt_row_color);
                y += h;
            this.left = x;
            this.right = x + w;
            this.top = c_y;
            this.bottom = c_y + this.visible_rows * h;
            this.column_w = w / no_of_columns;
        this.populate = function(gr) {
            th = gr.CalcTextHeight(".", font_std);
            // Should be consistent
            x = this.left + column_indent;
            y = this.top + (row_h - th) / 2 - 1;
            min = no_of_columns * this.offset;
            max = Math.min(no_of_columns * (this.offset + this.visible_rows), this.tags.length);
                tag = this.tags[n];
                font = font_std;
                if (tag in active_tags)
                    font = font_bold;
                tw = gr.CalcTextWidth(tag, font);
                while (column_indent + tw > this.column_w) {
                    if (tag.length == 0) break;
                    tag = tag.slice(0, -1);
                    tw = gr.CalcTextWidth(tag + text_omitted, font);
                if (tag != this.tags[n]) tag += text_omitted;
                gr.GdiDrawText(tag, font, tag_name_color, x, y, tw, th);
                x += this.column_w;
                if ((n + 1) % no_of_columns == 0) {
                    y += row_h;
        this.check_mouse = function(x, y) {
                idx = this.check_index(x, y);
                if (idx < this.tags.length) {
                    this.toggle(idx);
        this.toggle = function(idx) {
            tag = this.tags[idx];
                dismiss(tag);
            else
                activate(tag);
        this.check_index = function(x, y) {
            idx = no_of_columns * this.offset;
            idx += Math.floor((y - this.top) / row_h) * no_of_columns;
            idx += Math.floor((x - this.left) / this.column_w);
            return idx;
        this.jump_to_index = function(chr) {
            for (t = 0; t < this.tags.length; t++) {
                tag = this.tags[t];
                first_chr = tag.charAt(0).toUpperCase();
                if (chr == first_chr) {
                    new_offset = Math.floor(t / no_of_columns);
                    this.offset = Math.min(new_offset, this.out_of_bounds);
                    return;
    function activate(tag) {
        active_tags[tag] = new label(tag);
        playlist_add(tag);
        update_playlist();
        if (mode == "&&") {
            this.offset = 0;
            tags.update();
    function dismiss(tag) {
        delete active_tags[tag];
        if (len_active_tags() > 0) {
            remake_playlist();
            update_playlist();
        } else {
            fb.ActivePlaylist = parent_playlist;
        if (mode == "&&") {
            this.offset = 0;
            tags.update();
    Init, defaults, main events
    mode = "&&";
    tags = new tag_list();
    locate_playlists();
    on_new_playlist();
    function on_size() {
        wh = window.Height,
            ww = window.Width;
        tags.update();
        draw_labels(gr);
        tags.draw_rows(gr);
        tags.populate(gr);
        say_status(gr);
        suppress_pl_events = false;
        // Won't do at the end of update_playlist(). Not sure how else to execute this last.
    Mouse, key events
    function on_mouse_lbtn_up(x, y) {
        tags.check_mouse(x, y);
            active_tags[tag].check_mouse("up", x, y);
        window.Repaint();
    function on_mouse_move(x, y) {
        set_hand_cursor = false;
            active_tags[tag].check_mouse("move", x, y);
        set_hand_cursor ? window.SetCursor(IDC_HAND) : window.SetCursor(IDC_ARROW);
    function on_mouse_wheel(step) {
        if (step > 0) {
            tags.offset -= scroll_step;
            tags.offset = Math.max(tags.offset, 0);
        } else {
            tags.offset += scroll_step;
            tags.offset = Math.min(tags.offset, tags.out_of_bounds);
        window.Repaint();
    function on_key_down(vkey) {
        chr = String.fromCharCode(vkey);
        tags.jump_to_index(chr);
        // Gets awfully wonky with non-alpha characters, whatever "vkey" is doesn't
        // mirror the common ASCII alphabet
        window.Repaint();
    Playlist events
    function on_new_playlist() {
        // Not a native event
        active_tags = {};
        parent_playlist = fb.ActivePlaylist;
        assess_playlist();
    function on_playlists_changed() {
        if (suppress_pl_events) return;
        locate_playlists();
    function on_playback_new_track() {
        if (playing_playlist_index != fb.PlayingPlaylist) {
            fb.RemovePlaylist(playing_playlist_index);
    function on_playlist_items_added() {
        on_playlist_x();
    function on_playlist_items_removed() {
        on_playlist_x();
    function on_playlist_switch() {
        on_playlist_x();
    var suppress_pl_events;
    function on_playlist_x() {
        on_new_playlist();
        tags.update();
        window.Repaint();
    Хотелось бы переделать все это дело под некую панель рейтингов плейлиста...
    Что-то типа такого (фотошоп), показывающего сразу количество и звезды
Название:	Tag Results_02-04-2025_03.jpg
    У самого знаний совсем мало, может кто возьмется...
  6. #56
    2 096
    Взялся было попробовать, но данный скрипт подсчёт количества треков по рейтингам из метаданных не ведёт:
ID:	2058 Нажмите на изображение для увеличения.
    Как работает с рейтингами из статистики не проверял, т.к. её не использую в последнее время.
    В общих чертах "хотелка" понятна, а какое её практическое применение, кроме лицезрения / сравнения разных плейлистов по рейтингам?
  7. #57
    23.10.2023
    61
    В менеджере создает плейлист Tag Results с количеством треков, попробовать это достать...
    Ну и посмотреть, что там этот скрипт за словарь тегов создает, может там можно чего подсчитать.
Название:	Tag Results_02-05-2025_01.jpg
    Иногда не хватает наглядной статистики по плейлисту, можно весь лист прокрутить, можно в Facets глянуть, но хотелось бы перед глазами иметь "выхлоп" с очередного сборника.
    Беру сборники/альбомы, прослушиваю, ставлю рейтинги понравившимся, собираю в свои сборники годовые, типа Бест2024 (по тысяче треков в год набирается) те треки, что с рейтингами 3-5.
    Неплохо было бы еще иметь общий средний рейтинг сборника
    Последний раз редактировалось g00drich; 05.02.2025 в 08:15.
  8. #58
    2 096
    Конечно "хозяин - барин", но по мне удобнее в Быстром поиске.
    Выбираем в контекстном меню:
    • Поиск в (Библиотека, Плейлист, Плейлист (активный), Все плейлисты)
    • Теги (Шаблон, Исполнитель, ..., Рейтинг)
    • Вводим значения и получаем результат в виде готового плейлиста
    На скриншоте результат поиска по всем плейлистам, из локальных / онлайн файлов и их количество.
